LEGO Icons 10331 – Le martin-pêcheur
35 €
Wire route for the Tail light?
Wire route for the Tail light? Empty Wire route for the Tail light?
Message  flyverjonas Mer 28 Déc 2022, 22:35
Hello, Im new at this forum. Proud owner of an ULC. I have a question about the tail light. My 2011 factory made MCR has a tail light, as shown on the picture below. I think it is made like that from new of the factory. When I bought the plane, it was only the glass housing, no light bulb or wires. I'v have made my own strobelight made of 3W LEDs and a micro arduino controller. Works pretty good, but it needs some power. I have looked down inside the tail where the light is mounted, there isn't holes through the "tail center base" for wires to that light.
As I can see, are there no holes between the "room" where the light is mounted and the "room" where the control push rod is coming up.
Wire route for the Tail light? Fb_img13
Wire route for the Tail light? Fb_img14
My plan was just to route the wire "up, over and down" as show with yellow below, but it is not a satisfying solution
Wire route for the Tail light? Fb_img15
How is the power wire for the tail light routed in the tail on others MCR?
flyverjonas
flyverjonas
Nombre de messages : 13
Constr./proprio. : MCR01 ULC sn:406
Wire route for the Tail light? Empty Re: Wire route for the Tail light?
Message  Max Cointe Jeu 29 Déc 2022, 14:56
Hello flyverjonas and welcome cheers
Probably like on my 4S there is room under the part where you’ve drawn the yellow line which you can access should you unplug the tailplane . Above is a picture showing this room.
Rgds
Wire route for the Tail light? 20210514
Nombre de messages : 828
flyverjonas aime ce message
Message  flyverjonas Dim 08 Jan 2023, 14:42
Super, I will look up there one more time and see my ULC have the same hole (tunnel) at that spot, next time I'm at the airfield.
Thx Very Happy
flyverjonas
flyverjonas
Wire route for the Tail light? Empty Update
Message  flyverjonas Lun 30 Jan 2023, 12:22
@Max Cointe, Now I have checked my MCR. It doesn't have the same wire tube/channel inbuild as your MCR. I stay with my first idea with the wire "up, over and down". But thx for your answer.
flyverjonas
flyverjonas
