-40%
-40% sur le Pack Gaming Mario PDP Manette filaire + Casque filaire ...
29.99 € 49.99 €
nouvelle directive Anglaise pour attache d'aile tous mcr avril 2011
nouvelle directive Anglaise pour attache d'aile tous mcr avril 2011 Empty nouvelle directive Anglaise pour attache d'aile tous mcr avril 2011
Message  bachelet Lun 20 Juin 2011, 17:29
bonjour,
je viens de trouver cela sur un site Anglais, mais rien en France...
Airworthiness Directive – Dyn Aero MCR-01 Series Aeroplanes
This emergency AD is prompted by a report from the manufacturer and the UK CAA of finding severely
corroded wing attach fittings on an overseas Dyn Aero MCR-01 ULC aircraft. This AD introduces an
inspection of the forward and aft wing attach fittings, and all the aluminium metal fittings on the airframe
for general integrity, security and corrosion.
DCA/MICRO/14 Aluminium Fittings – Inspection and Replacement
Applicability: Model Dyn Aero MCR-01, MCR-01 Club and MCR-01 ULC aircraft, all S/N.
Requirement: To prevent potential structural failure due to possible corrosion, accomplish the
following:
Inspect the forward and aft wing attach fittings for general integrity, security and
corrosion per the instructions in Light Aircraft Association (LAA) Airworthiness
Information leaflet MOD/301/022 issue 1 dated 18 April 2011. It may be necessary to
remove both wings to accomplish a thorough visual inspection of the forward and aft
wing attach fittings.
Inspect all the aluminium metal fittings on the airframe for general integrity, security
and corrosion per the instructions in MOD/301/022.
If any defects are found replace defective parts, or accomplish a LAA approved
repair, or a manufacturer approved repair before further flight.
Note 1: A copy of LAA Airworthiness Information leaflet MOD/301/022 issue 1 dated 18 April
2011 can be obtained by emailing LAA Engineering at engineering@laa.uk.com
Note 2: If any defects are found at the initial inspection report the findings to the Light Aircraft
Association (LAA). It is anticipated that the repetitive requirements of this AD may be
revised depending on the defects found at the initial inspection.
(UK Emergency MPD 2011-002-E refers)
Compliance: Within the next 25 hours TIS or by 13 June 2011 whichever occurs sooner, and
thereafter whenever the wings are removed, and at every annual condition inspection
for aircraft stored outside, and for hangared aircraft at intervals not to exceed 3 years.
Effective Date: 13 May 2011
bachelet
bachelet
Nombre de messages : 1
Constr./proprio. : dyn'aéro/propriétaire n°307
http://francois.bachelet.free.fr
nouvelle directive Anglaise pour attache d'aile tous mcr avril 2011 Empty Re: nouvelle directive Anglaise pour attache d'aile tous mcr avril 2011
Message  Admin Jeu 23 Juin 2011, 06:41
Effectivement, pas de trace en France pour le moment...
Il arrive que les anglais éditent des SB non suivis par le reste de la communauté européenne, et même sans en informer le constructeur.
Toutefois, elle est sûrement dû à une constatation de défaut sur un avion sur leur territoire, voire le résultat d'une enquète accident (l'AAIB est un très renommé bureau d'enquète accident).
A l'inverse, le Royaume-Uni ne suit pas forcément les SB constructeurs et EASA, ce qui explique pourquoi il est si aléatoire de pouvoir immatriculer un avion "Golf" en "Fox", ou à grand frais avec notamment l'application de tous les SB à prévoir par l'acquéreur... Et je ne parle pas des avions de construction amateur, y compris les kits.
