MCR-4S excessive Play in Ailerons - Is there a "Bush Kit" available.
Hi
Is there a "Bush Kit" available from SE-Aviation and its part number for bushing my ailerons. I have excessive play. I will order from Lydie, SE-Aviation once I have the correct information.
The parts affected are
11.01/15 QAIREDI02 VOILURE AILERON POTENCE INTERNE CARBONE x 2 and the sister fixter
11.01/15 QAIREDI03 VOILURE AILERON POTENCE EXTERNE CARBONE x 2 and the sister fixture
Apologies for English hope you understand what I mean.
Thanks Peter
Thanks Peter
Re: MCR-4S excessive Play in Ailerons - Is there a "Bush Kit" available.
HI Peter
Yes, Lydie will send them to you
I have just changed mine, but the price is sky high, 32 euros each, you need 8 for the two steering flaps
You may not bother searching, but if I had to do them again, I would find them somewhere else. I have posted a photo on the subject "jeu au commande des ailerons"
It is simple a tube with a washer welded on one side that you are going to glue to the previously enlarged holes. It is a problem on machines like ours where the joints are in carbon fibre, in comparison with earlier versions that were made in aluminium.
I hope is helps!
Alfredo
I hope is helps!
Alfredo
Gajoubert- Nombre de messages : 74
Hi,
If you decide to make them or not!, just bear in mind that the inner hole of the tube must have the same width of the bolt, in order not to have play. Then measure the outer width of the tube and use the same width drill bit to enlarge the original hole in the joint of both the flap and the wing's bit.
I say that because there won't be any instructions with the kit.
Sorry if it is too evident, I just try to help
Do you farm in New Zealand?
I am spanish ,married to Sarah, welsh, we farm in France, beef and sheep, extensively, like down there in your world!
I fly off my fields on the farm, I love it! The mcr is so nippy in the air, its like flying on the top of a pigeon!
Regards
Alfredo
Regards
Alfredo
» consommation excessive de carburant
» jeu au commande des ailerons
» Pilote automatique
» Jeu des ailerons-flaperons d'une MCR01 vla
» servos trim d'ailerons
